How do you tell the difference between 1.0 and 1.3 cams?
Cg10 has 6.05mm of lift
Cg13 has 7.95mm of lift
Sent from my CLT-L29 using Micra Sports Club mobile app
Far simpler to measure the overall camshaft height, as detailed in the maintenance manual.
Thanks very much people for the replies, i saw a set online and they had 13 then 00 stamped into them. Does this mean anything? Thanks.
Just to add are these a direct fitment onto the 1.0L K11 CG10 ENGINE or is there modifying needed. Hoping to use it on my daily driver 1996 Nissan micra k11. Thanks.
Direct fitment, no modifying needed. Just do one at a time though, that way you can jam the other sprocket while you change one side, so no chance of messing the timing up.
