just the shock, and then stand on the drum
Tie some rope to them, tie the other end to the lamppost then drive off :laugh:
I jacked up, took of rear wheel, unbolted the shock at the bottom, the used spring compressors
Seriously though rears are easy.... With the car on the ground undo the top bolts for the struts, jack the car but not by the axle
Everything should have lowered so you can pull the springs out
You have to do both sides otherwise the axle is being held in place by one shock
thats what me old man said as well, cheers karl (Y)
And he has right! (Y)
