L.Williams
soundcloud.com/lwilliamsmusic
dunno how to remove the iarbox from the throttle body, its a micra 1.0 evaluation, i need to fit my induction filter i can only find one screw that un does it, but it wont budge PICS >?????????
thanks bro, youve always helped me out on here haha, cheers! right i know the screw, only it wont undo? is it always that tight ? its not rusted, just looks really gunky and oily, any tools i could use ? hahathere's also a screw to the right, near the breather pipe.
Undo that and the jubileeand the box will pull off with a bit of twisting.
Trying to cast my mind back, are you able to fit a 8mm or 10mm socket over the top and undo it that way?thanks bro, youve always helped me out on here haha, cheers! right i know the screw, only it wont undo? is it always that tight ? its not rusted, just looks really gunky and oily, any tools i could use ? haha
over the top of the screw ? ive got a twist socket, well my dads, and it has loaddssssss of little pins, that once pushed onto a bolt will grip it, if you get me ? fits any sizeTrying to cast my mind back, are you able to fit a 8mm or 10mm socket over the top and undo it that way?
yeahhh thats the little prick! haha and okay man cheers, my test in 11 days, better ****in pass this one! jheezeThis one yes?
Looks like you can fit a small socket over it. But if you're not bothered you can pull the airbox off and it'll just snap off.
- unzip and detach the inlet pipe from the airbox
- the airbox is anchored to the engine via a 10mm bolt under the airbox inlet port. use a socket cos its kinda tight. I once forgot bout the bolt and snapped the plastic mount off when i pulled the airbox off. it's not essential anyway
- look under the airbox from the drivers side and there's a jubilee clip clamping the airbox to the TB. loosen the clip with a 8mm thin long socket or screwdriver
- also loosen the small spring clip on the engine cover L-breather pipe so u don't snap the plastic pipe off when removing the airbox, I use molegrips to hold the spring clip open
- grab the front and back of the airbox and tilt/rock it back n forth whilst pulling up till it comes off the TB
- pop the breather L-pipe off the engine cover
- there maybe a thin vacuum line under the airbox
