How do I get the Lambda (Oxygen) sensor out on a K11?
CMF_Paul_L
Car is a 1.4 auto and has 2 fans behind the radiator. Job would be dead easy if it only had the fan on the right (facing the engine compartment). The 2nd fan is held in by two bolts at the top and I think two more bolts at the bottom. I am just trying to avoid having to jack the car up and take off the under engine shield to get at those bottom bolts. I bought an extractor tool Franklin TA902 but it won't fit as it fouls one of the support brackets for the second fan. Franklin do alternative tools that might fit. Does anyone know a tool that does definitely fit with the 2nd fan in place?
