how do i enter the radio code?
As an example If the radio code is 1234, you have radio preset buttons on front panel of radio, using button number 1, ensuring that the display shows 0000, press button 1 till first digit reads 1 and then press button 2 till it reads 2 and then press button 3 till it reads 3 and same for button 4, depending on which model radio you have fitted to your K12 micra will depend on next stage but after you have entered the radio code into the unit the display will show your code, either press volume up or tune station up or press and hold the TA button, display will either show CODE OK or will default to WAIT 10 which is wait 10 mins till you can try another code.
cant be the right code then, i know when i enter mine as soon as last digit goes in it switches on automaticly
That's what I thought, the last one I did was the same, I found that guide for other blaupunkt code radios as he said it didn't work, but I don't think he's been back online since I sent him a new code
Hi,
If you are getting the wait one hour, you actually have to wait the 1 hour with the ignition tuned to the on position. Not so the engine is ticking over but to the bit where your dash lights up. Then wait the 1 hour, do not turn off the car before the one hour or else you will to start the 1 hour all over again.
If you wait the hour as described above the radio panel will go back to displaying 0000 and you get another 10 attempts to put the code back in.
You do that how gtsnissansab explained above.
Hope this helps.
i have a radio QQ 2007 in my nissan micra and was wondering if u had a code for this ive went to the garage and they said they don't do codes for these radios anymore.
