Hi,
My Nissan Micra Spirita is second hand, but new to me and it's a 56 reg.
I've tried the Air Con and it seems to be working fine, but I've been told that as the car is coming upto 6 years old, it will need a full service with everything changing, but nowhere in the manual can I see what - pertaining - to the Air Con actually needs changing.....will it be just the filters or is there a gas canister? The manual, tells me virtually nothing about the Air Con, it just tells me to go to a Nissan Dealer. Obviously, I don't know if the previous owner used the Air Con regularly or not, so I don't know if anything has been changed from new.
Is there an indicator on the dash which tells you the Air Con needs changing?
The thing is, I go to a mechanic who I have been with over 25 years. I don't want to go to a Nissan dealer because I know a dealer will charge the earth, so is the Air Con something which can be sorted by any mechanic, or does it need to go to a Nissan Garage?
I would appreciate any advice please.
Linda
Linda
