CMF_DECIM8
» CMF MemberIm rather stumped. Ive got my twin horns wired up as normal. When I sound it nothing happens. The relay triggers I can hear it fire, power ends up at the other end but the horns dont sound.
If I pull the clip off and just touch it the horn sounds (to my shock lol) The horns work, I know that. I just cant understand why it wont sound on command. I have sanded down the connections and made a jumper from the wire to the horn with the same result so its not the connection.
I did spray the horns red so it may be why, anyone know if any connections sit under the horn itself which would disable the horn sounding? I also tried another horn which did not work either?!
Help!
Help!
