Horn + aftermarket steering wheel.
CMF_ed.
After I installed a momo steering wheel the Horn doesn't work.
I have an alloy spacer between the hub and steering wheel.
Could it be the spacer causing it?
Ed
CMF_lam.666
have you tried the horn with the steering wheel and spacer not present?
is there a fuse for the horn?
if the alloy spacer aint touching any connections with the horn there shouldnt be a problem ...
and ed. whats that site u told me about to import parts from japan.. which is not slidewize
CMF_evade
you connect one part of the horn coming from the steering hub to the horn..the other one has to be touching a ground somewhere.
i just ran a wire off to the side and touched the metal.
play around with it wihtout the steering wheel bolted on until you get it working.
