Hiya , just brought myself a nissian micra 1999.....got given a parrot kit so thought id install it....... I have fitted a few before, any way long story short. took out stereo which wasn't original one was an aftermarket jobby alba, previous owner didn't bother buying harness adaptor and decide to chop wires and bullet them together... earth wire wasn't connected as I believe it earths threw Ariel ... so for parrot kit to work needed to find a earth there was a wire from oem block which was for original stereo wasn't used as it was cut and just dangling, did a continuity test to see if it was an earth and it was so joined it to parrot block.... everything worked fine stereo... parrot etc but tonight when I went to turn on tail lights I had none..... brake lights and dipped lights worked, so thought it was a fuse changed it and everything worked for a second an it popped it again..... I had one more fuse left so decided to disconnect earth to parrot and Ariel and put new fuse in, connected stereo and tail lights staying on all the time soon as I connect areal in they go off? any ideas only got car today....so was a bit annoyed as been trying to fix it and figure out what's wrong using phone flash light
what ive done it disconnected stereo so tail and dash lights go off , so I don't have a flat battery tomorrow but soon as I connect power block on stereo they come on and stay on, if I put Ariel into stereo they go off ......? seems like stereo is back feeding giving them a p+ feed?
I apologise for pure grammar been up since 6, its been an extremely long day !
