high revs
hello,my k10's possessed! i'm braking & changing down thru' the gears & there's sudden high revs.going into neutral seems to calm things.anyone know what that was/is? regards
first suspect is a sicking throttle cable , peddle (chech that the carpet or cables under the footwell are not interfering) or mechanism on carburettor
check everythig is totally free
hello & thanx your advice.i'll check those things;but the HT leads seemed a bit loose.could that have been it? regards
I doubt it , but push it back on anyway! that would cause a misfire not overrevving. As frank said possibly vaccum hose or somethng sticking.
