CMF_Blueman
» CMF MemberHello,
i have a 1995 Nissane Micra LX 1.3 EFI. this past couple of weeks when i am driving and stop at a set of lights the car will keep idleing at around 2.5K rpms.
When i start the car in the morning all is fine.
I have cleaned the air flow valve with carb cleaner but the car still idles high.
when i disconnect the connection to the air flow valve the car will idle back down to normal, but when i insert it in again the revs go up.
do you think it could be a faulty valve or the throttle body it self.
I have tried to see if the ECU outputs any error codes but i can't find the hole to turn the screw and i don't have any torx screw drivers
help will be very greatfull
thanks
thanks
