High comp cga3
Hi all, after advice please.
Does anyone know if the comp height and pin dia is the same on cg10 and cga3 engines?
Need to get more compression in a rally cga3 engine and was thinking the easiest way is to get a set of +1mm cg10 pistons.
Any other suggestions?
Cheers.
cga rods are the same length as cg13, so the pistons will protrude like so
