Been looking at the Cube X spec CGA, they quote a comp of 10:1 and just over 100hp, i know they had a tubular manifold on them, so that helps get that power. Looking at the bore and stroke of mine and the cube cga, and they are the same, so it looks like the clearance volume in the cube is different, at 37.46cc if i worked it out right, whereas the normal cga has a clearance of 39.66cc, a 2.2cc difference. Could that be taken off the standard CGA head to get that compression?
