wehey
i have just got back for the Mot and the only fail I had was emissions.
A little history since the last MoT?....
Swapped out the 1.0L for a low miler 1.3L (40k auto block)
I still have the 1st cat but recently fitted a Sported exhaust which deletes the 2nd cat.
I have a spare lambda, original exhaust and spare 1st cat in the shed.
Now as far as I know you should be able to pass the emissions with just the 1st cat.
So my options are:
Swap my 1st cat and lambda for my spares and hope they are ok
Re-fit the original, stock exhaust
Do both of the above just to be sure.
Below are my readings. What should I do next folks? Can anyone tell from the readings what could be at fault?
So my options are:
