hi , i have just refitted my stereo in my car because before i was using it just on the accessory so i had to reset the bass/treble etc everytime i wanted to use it. i have now put the 12V constant wire on which runs straight from the battery +ve terminal. but everytime i touch the drivers door i get a nasty static shock!!!!!!! i dont know whether this is dangerous or what i should do to prevent it? i have used the brown +ve wire that my old original radio was linked onto and this is only active when the accessory position is activated by the key. i have used a black wire with a yellow line that is next to the brown wire as the earth. The cd player works fine just as normal all powers up, has its memory...perfect!! i was looking for some advice as to whether this is normal or maybe something wrong?
please help
thanks adam
please help
thanks adam
