help with carb
L
lesmondo
hey first post on here lol. i'm havin a bit of trouble with my carb i'm a mechanic, a nissan 1 at that but i've never worked on a k10 before. theres a vaccuum pipe on the left hand side below a diaphram thingy and i haven't a clue where it goes if some1 could take a pic of the side of there carb or can explain to me where it goes i'd be gratefull
can any1 help me here and is there any chance i can put a photo of my car in ere
I'm not sure without a picture but if it is a small bore pipe it might be for the idle control in the air box.
On one end ther is a Y pipe connector that goes in to the main vacuum on the other there should be a wider rubber connector that goes to the bi metalic strip inside the air pan
