I have recently bought a DCi and found the gears are sometimes sticky! Also the reverse sometimes requires double clutching to engage. The car only has only covered 35k!
Can anyone tell me what the problem might be please...?
Thanks and hope someone out there gets back to me.
yes i can tell you exactly what the problem is , its just ya cheapo gear box lol nearly every k12 has the same problem mine does thats for sure and its only just done over 30k lol mate ither replace the gear box or drop it off a cliff lol (really tho it gets better in the summer its the cold weather that the micra dosent like lol)
it sounds like the gearoil is too thick then, we have the same problem with our wet clutches at work, and i always fill them with 50/50 engine oil and diesel fuel in the winter, and neat engine oil in the summer
where is the gear oil situated?il check my manual lol see if that helps i have also found out that if i sit my seat a bit further forwad that helps!!!!
