Not sure if you can buy the scuttle panel. If not, I think you could just cut out the metal where it's rotten, shape a new bit of metal into whatever size/shape you need, weld it in, then just go over it with some filler, sand paper, and spray paint. Probably cheaper than buying and replacing a whole panel (Y).
