Allright guys and gals, back again after a wee spell!
In desperate need of help with a few problems on the micra. I seem to be having issues with the electrics, which is a pain as I'm not sure exactly whats wrong or how to describe technically, but I can give it my best shot.
I posted up previously that we had stereo issues - ie no power feeding through. Eventually, after much cutting and switching power got through, a bit more and some sound got through too - though it had the result that seveal fuses popped, taking with them the back lights on the car.
The upshot is the stereo is still not working - although the idea of hard wiring power straight from the battery is now being mooted?
Also, the drivers side rear tail light is giving me a headache. Just went for a drive, I seem to loose the taillight when it switches for brake, then loose both when I let the brake go. (if that makes sense) - this likely to be a dodgy bulb/conection or wiring issue?
I also appear to have lost the washer jets - theres water in the system, as far as I can see there are no relating fuses, and certainly none that have blown. Interestingly enough I still get wipers...just no washers!
At wits end so any help gratefully appreciated. As I said, Im pretty #### with electrics, but I can try to get any answers required if it helps solve the problems!
Cheers,
Martyn
Cheers,
Martyn
