HI All
Mate's daughter has a 1 litre P reg micra, seems to be same as my M reg 1 litre engine/parts etc.
Its chugging, holding back quite badley when you put it under load.
We have tried the following to sort but with no luck:
tried the dizzy unit from mine
tried driving with & without lambda plugged in & no change
hers has had a new:
dizzy cap & rotor arm
new plugs
new leads
oil & filter
air filter
fuel filter
we have tried carb cleaner through the throttle body to clean out etc
and still doing the chugging/holding back etc.
Only parts left i can think of are:
the circuitry under the plate on the throttle body could do with a solder up?
fuel pump playing up (but issue is only when wanting to accelerate)
or idle control valve could this cause the hesitation?
any help asap please as his daughter really needs the car for work.
cheers folks
hers has had a new:
new plugs
new leads
oil & filter
air filter
fuel filter
cheers folks
