jabran200
O.k heres the situation. My car started to misfire on cylinder 1 only so i thought could be injectors, plugs or leads but plugs and leads are good the injector is still in the socket but using a multimeter i checked the voltage on ignition and crank and was getting 5v and 9.2v on both injectors one and 2 so assume the rest are the same.
Just to eliminate the injector totally I plugged the injector plugs into a spare primera fuel rail and injector too spits fuel but when injector 1 plug is connected to same injector on the primera rail i get no fuel. But why is it getting a voltage then but refusing to spit fuel out??
What could it be? I am leaning toward ECU. Only problem is my car is Nats so plugging in another ecu to check is a prob but i might be able to get a mates ecu in and his nats key to check. No nats ecu didn't work as wiring is different.
What else could it be?
Thanks for reading my problem. I really can't figure it out?!! What else could it be?
