CMF_redland_doug
» CMF MemberHi,
I moved my K11 a short distance yesterday, and now it won't start. I thought that I had committed the usual sin of not letting it warm up enough, so I did the take out the fuel pump fuse, crank her over till she fires .... but she didn't. I actually flattened the battery I tried so hard. Fuse in, fuse out, no starting. Even tried with a jump off another car. Nothing - cranks away, but no sign of life.
Anyway, I removed & recharged the battery over night. Today its the same story. I just noticed that the orange engine management light is not coming on at all when the key is put in, and it should as I recall. I believe this is the real culprit, but how to proceed? I've checked all fuses under the dash and under the hood (that I could find), but all are fine. I even tried the bent piece of wire trick on the ECU connector to see that could coax any life out of the engine light - nothing.
As ever, all advice very gratefully received.
Cheers,
Doug
Cheers,
Doug
