New to the area and Went to a new MOT centre and they failed her car on the following things:
Offside stop lamp not working
Registration plate bulb not working
Nearside track rod end ball joint has excessive play
Offside track rod end ball joint has excessive play
Offside front suspension arm has excessive play in a ball joint
Nearside rear tyre tread depth below requirements
As she had been told this centre only did mots and not repairs they failed the car on the above and then quoted over £200 to get the work done on top of the £48 for the failed test.So was in there interests to fail it if they felt we would get the work done wih them.Does this sound reasonable or excessive?
The bulbs and tyre we can fix ourselves but not sure about the other jobs,does anyone have a rough costing of what each job should cost so i can shop around for the best deal.
