HELP need a new ecu
can anyone help my son out with an ecu for his first grass track car the ecu number is 0261200957 pre 95
thanks for anyone who can help or point me in the rite direction cheers
ive never noticed, i used to run a pre-nats ga16 ecu and that was a different shape, but worked great when combined with throttle body and injectors.
if the connections are the same it should be fine :)
the ecu are different size and the plugs are different also
Ive never seen a different sized plug personally, even nats mats micras plug in they just dont run due to obvious reasons. Where did you get this different sized ecu from?
its only the obd2 (coilpack) plugs that are different eh stani (more square shaped) the nats ones are just a different pinout eh
