CMF_devilstickz
» CMF MemberHi guys,
I rewired the headlights yesterday because I had the old melted fusebox problem, so I took the two red wires and the large white and blue wire off the fusebox and spliced in two in-line fuse holders with 15 amp fuses. Put it all back together and the headlights work fine now.
However, when I try to start the engine the check engine light flashes (a NATS problem). The first time the engine actually fired up then died after a couple of seconds, now it won't start at all (starter motor turns but engine won't catch). The light flashes whenever the ignition is turned on.
When I reconnected the battery after the wiring there was a spark from one of the terminals, could I have fried something?
I tried leaving the battery disconnected overnight but the problem is still there.
If anyone has any ideas or has had a similar problem I would be very grateful for any advice...
John
(at least the headlights work now, eh?)
John
