https://m.facebook.com/story.php?story_fbid=10155698504252843&id=314037332842have you got a vid of it vishva ?
I thought as well as u,so I have double checked TDC marks according to technical manual,then All the valves were grinded and smoothed,but the problem isn't vanished.please give is there another problem..Sticky/badly seating inlet valve? Cam shaft timing out? (cam to crank TDC)
Well obviously one or more inlet valves are not fully closed when the pistons start to rise ......valve clearances too tight/non existant then?I thought as well as u,so I have double checked TDC marks according to technical manual,then All the valves were grinded and smoothed,but the problem isn't vanished.please give is there another problem..
Tnx dear,I have already kept valve clerances high.about 0.5mm,please tell me how to find valve leak from which one..Well obviously one or more inlet valves are not fully closed when the pistons start to rise ......valve clearances too tight/non existant then?
yes it does sound like the cam is retarded a couple of teeth, have you checked the tdc pulley mark with a screwdriver down the plug hole ?
and checked the inlet is starting to open and the exh nearly closed on cyl 4 ?
Dear frank ,first i kept timming sharp correct,Yeap dear
Thanks.i usually roll mine down a hill in gear to test for 1 or 2 low compressions (handy for diesel engines) select a gear that rolls about walking pace, and feel for 4 equal resistances
I would suspect a head gasket blow between No1 and No2 cylinders, due to either a warped head or cylinder head bolts in that area not torqued down correctly........No,u got wrong idea,plug hole was fully opened one by one,Therefore no compression in cylinder,so no pressure act on air intake due to inlet valve leakage,have got the theory bro..
Not sure that fits in withi suspect 2 bent inlet valves personally, a result of trying different tooth settings
Definitely wouldn't hurt to try it, always do the simple things first, though I thought that the OP had discounted this? . Firing order 1,3,4,2 ?compression would leak out of the sparkplug hole and not back through the carb, and more-so with both plugs removed.
the engine sounded like it was running on 2 in the vid, and may have been running on 2 since the rebuild (hence my suggestion to swap sparkleads 1 and 2)
