so i need to fit a cg13 gearbox into my car and i need to do it inside a day!!
so i will defo need a cg13 gearbox, cg13 clutch, cg13 flywheel.
i have clutch and flywheel and actual fitment of clutch, flywheeel and gearbox is a piece of cake, i have that covered
iam guessing the clutch cable is identicle and possibly speedo but i dont care about speedo.
Ill need to make new shafts but thats fine also, about an hours work.
BRAIN STORM BITS
so what about the actual mounts? surely if i get the mounts that match the cg13 gearbox its a straight swap? anyone know? OR are the mounts specific to 1300 shells or cradles??
and what about the gear linkage? is it the same as -96 cg10?
BRAIN STORM BITS
