if the standard head unit doesn't have wires for the rears then you could splice into the exisitng fronts. however it would probably be best to get a new headunit that supports fronts/rears/ and an output for a subwoofer.
then all you would have to do it get some new speaker wire and feed it through to the back.
Good Luck!
