Paul Smith
Site Supporter
Hi i was after some suggestions,
My micra has been having some difficulties as of late, here is the story so far:
about 2-3 weeks ago my micra seemed to have a little trouble starting it had to turn for a little while before coming to life, she was very jurky all through the rev range. As the days went past the micra was getting harder to start. Until finally tuesday morning she said no way and just turns, So i thought i'll have a look. The plugs were as black as anything obviously running way to rich. So today after work i fitted new Bosch super 4 plugs, new throttle body with air meter, Cleaned the lambda sensor (also Black) and fitted a new water temperature sensor, checked the leads to make sure they were seated right but she still only turns. It doesn't sound like she is even trying to fire now. I will test for a spark in the morning when there is some day light again and i have a fresh set of eyes to see with.
I was hoping for maybe some other suggestions as to what it could be???
Paul
Paul
