Help!! Fuel Issue..
Hi there I have a problem with my N reg Micra (95)
Recently the car has been involved in an accident in which it has been written off. Before it goes to the breakers for scrapping, does anyone have any ideas on how to siphon out the fuel? There was just over 3/4 of a tank at the time :S It would be really useful to get the fuel back before the breakers pick it up tomorrow. Thanks for any help you can give!
R.I.P Betty, She was a perfect little runner. :(
get a pipe and start sucking! haha only joking you should be able to drop the fuel tank down if you jack up the car and put it on stands, then the rest is straight forward really
i would use the pump thats in the tank:) put the return fuel pipe that comes off the presure regulator (you may want to extend it) and put it in a suitable container, then run the engine and let the pump do all the work for you;D
