HEEELP CAR DONT START!!!
CMF_Alex_B
Are you getting spark/ignition?
pull out one spark plug and put it back into the ingition lead, while holding the lead, rest the body of the plug on the motor to earth it ( so you dont get zapped), then watch the spark plug while an assistant turn over motor and see if you are getting any spark,
Alex
CMF_vdl1k
if you have not got a spark sounds like water may have got into to the ecu common problem remove the ecu and remove the covers you will soon see if water has damaged the circuit board (check both sides)
