Hello!
I'm having some issues with my car, as the rear of the car vibrates a lot at speeds between 90 and 110Km/h.
I was entirely convinced that the issue was the shock absorbers, as all four were leaking, and while i was at it, i also replaced springs for -30mm (H&R brand) so the car actually has a quite sporty feeling to it. I like it...except that the vibrations are now much worse because now the shock absorbers are actually doing its job.
The car was vibrating before tyre replacement, as well as before rim replacement, and while it could be, it's unlikely that the tyre shop messed the equilibrium two times in a row, only on the rear wheels, so while i'll try swapping wheels in and out to try, i'm not really keen on that idea.
I haven't checked much more back there, maybe some silentblocks are aging, but i don't see what could be making this mess. I went for the shock absorber idea as it felt like the wheels were bouncing instead of staying planted on the floor, but doesn't seem to be the case anymore.
I hope someone can direct me to an actual fix!
