Hello guys,
I've got a problem and I hope someone can help me, my 1.2 super s has developed quite a heavy stutter when using partial throttle.
Somethimes it can be so bad, that when pulling away from standstill the car will just stall as soon as I lift the clutch a little, resulting in pulling away with 3500 rpm and looking like an idiot :blues:
It comes and goes, and it feels like it only happens when the carb is only using the primary barrel, at constant speeds, and with less than about 75% throttle. (when it stutters and I put my foot down completely, the car just starts pulling normally)
The carb has already been cleaned completely, was ok for 2 days then started stuttering again.
When it happens it's usually with a warm engine, but it happend with a cold engine a few times as well.
I have no idea what it can be, everything looks perfectly fine, but something must be wrong.
Fuel filter is clean, oil is ok, plugs are ok, already threw in a bottle of carb cleaning stuff.
Nothing works.
(1.2 super s, without egr or katalysator, about 87000 miles)
I really hope someone can help me, because I'm starting to get a little desperate!
Thanks in advance
Nampus
Nothing works.
Thanks in advance
Nampus
