OK so I have a 2009 1.5dci with 50k miles
It has been serviced religiously every year but has only done a few thousand miles in the last few years (old owner + pandemic)
The car has spent most of its life near the south coast. I was worried about a corrosion horror show but mostly it looks really good.
On getting it home the steering had not really improved much so i lifted the front and took the wheels off to try and see if there is something binding in the steering/suspension setup. visually it looks ok except the front hub carrier and strut are super rusty. On turning the steering lock to lock (in the air under no load) you can hear a creak from passenger side strut top mount and see both struts top nuts moving.
PS light goes off fine.
Is this a common issue, what parts do you recommend I replace if so and any recommendation on decent brands/places to buy.
