robbluek10
hi all this is probaly a silly one i was working on my car last night and i got cold so i started her up and got the engine nice and warm then put the heaters and i noticed the centre console heaters the ones which u can move around will only blow cold air no matter where i set the gauges to so i checked the window heat setting all fine and the feet setting is ok to and i found that the other vents in the dash that can be moved around to only blow cold as well is this meant to be like this or do i have another job to do on the car if so how do i fix it :down:
