Ah ok, this is quite a common problem and means that the heater resistor card/pack is faulty. It's situated just up behind the glovebox, right in the left corner of the passanger footwell.
You can often get them cheaply from a local breakers yard, or even fix it yourself if you have a soldering iron. Otherwise you can get a new one from Nissan, but expect to pay through the nose for one!
