Heater/fan broke
C
Clone
Hey all im new here :)
Got a problem with my micra:
It used to only work in speed 4...but now it doesn't work at all, the heater works i think but the fan doesn't? i mean if u turn heater on a drive on the motor way the screen will eventually clear with the hot air being fourced up....It goes through 2nd hand fans like nothing else Anyway, we thaught it would need a new fan again but the guy at garage said the heater is not working basically It's blowing loads of other fuses and would be a big job?
So what do you think? Any advise?
This has been asked 1 billion times! so do a search for resistor card or fan speed problem etc and you'l probably find what your looking for
Sorry about that as i said i am new here, the resisted would that matter is the heater/fan isn't working at all? Or have you also missread and thinking its just not working unless speed 4? Once again sey *begins search*
make sure the fan blades are clear from debris like leaves and dirt and the bearings and brushes are ok then try a new resistor card.
K well i will be able to attempt that on saturday if im allowed to do that :p
