CMF_patrick reilly
» CMF MemberBlower motor suddenly not working on any switch position .Fuses examined and found OK. Most blogs suggested Blower resistor failure which is expensive. Luckily I persisted with search for loose elec. connection (thanks to "Dragonfly" blog). Eventually found four wire connector to blower resistor not fully engaging.This is located behind glove box compartment.Press very tightly together until plastic catch clicks, to ensure engagement of pins.
