hello all , my heater blower was working intermittently only on 3 and 4(would usually have to wiggle the switch) then it jusg stopped altogether ,having googled I seen the common resistor card problem so went and bought and fitted a new one but no good.
I can't seem to locate the heater relay to test it so im guessing its in the box under the headlight? there is 2 relays on the interior fuseboard but it doesn't say what they are for .
the other thing I was thinking is maybe the switch itself is broken (possible? ) I have tried wiggling the connection at the back of the switch and also the connection on the motor itself but still nothing. there is power at the resistor card which I believe comes from the motor so the motor must be getting power too right?
I was going to remove the stereo to change the switch but then seen all the threads about radio codes! so would like to find the relay first before I do since I will most likely need a new stereo afterwards and don't really want to fork out the cash.
any help would be appreciated .
ok well I found the relay and swapped it with the one next to it still nothing so I proceeded to remove the switch which looks like its nicely corroded, waiting for a call from the wreckers for a replacement.
