Hi folks!
Noob here. I see a few threads asking about headunit changes but I've found none that answer my query.
I bought and had someone fit a JVC headunit, to replace the factory fitted one in my Nissan Micra K11 n-reg 1.3 GX.
It works ok.. ish.
I used an iso converter from e-buyer.com, namely a PC2-13-4 and it fits and does the job. The only thing I can't suss out is why, whenever the ignition is switched off, the radio loses it's memory?
I can set a station to a preset, turn the radio off and turn back on with the ignition on and it recalls the stored preset. So it's not a fault with the radio.
Now, as far as I can tell, there's no seperate black wire going to the chassis (however, I've yet to have a proper look myself) but then there's none of the weird fuses blowing or lights not working properly - they all work fine. Whether this needs doing, I'm not sure. What I'm even less sure of is which black wire is it??
Also, is there a wire in the wrong place on the iso converter, as I'm pretty sure the headunit should be remembering radio station presets from one day to the next.
Here's hoping some kind soul can help me out.
What I can do is post a list of what wire is going where, when I have a look.
It works ok.. ish.
