headlight removal
CMF_mycra
3 bolts holding them lights on each side... have to remove the grill first easiest way is to use a flat head driver and pop open them clips.
one screw is on the front exterior holding the guard to the light. and other 2 are on the inner under the bonnet.
CMF_Mimz
yeah ty dude...still waiting for the center light tho. Just discover today as well that the passenger side CV boot is leaking **** from it so in da process of fixing it. Any chance u might have some power tools to help remove drive shaft. Got stuck on da big nut that hold the shaft to the spindle.
CMF_mycra
yeah il bring it next time i come by... but you should be able to get it off with them socket set you got....since you're gonna be removing the cv might as well start undoing the Gearbox as well so we can fit the clutch...
