Hi guys.. at first it was just the right but now it's both headlights that are not working. The full dips work and the use the same bulb as the headlights, kinda strange, am i right in assuming this is not a fuse issue ?
If you suspect it is a fuse issue would it be a fuse under the bonnet or inside the car ??
Please give as much info as possible as i'm fairly newbish to this stuff :grinning:
Thanks in advance for any advice, much appreciated.
David
David
