Headlamp Bulb
Disconnect the headlamp connector , remove rubber cap , remove retaining spring lock , then remove the bulb, refit in reverse.
Parking bulbs
remove connector , remove rubber cap , then remove bulb.
Turn bulb socketCounter clockwise and unlock it
Removing Headlamp requires
Removal of fender protector then , remove bolt of front fender front end and bolt of front bumper fasia.Remove front bumper fasia.
Disconnect the headlamp , park light and headlight aiming connector
then remove headlamp bolts , then pull headlamp forward while raising top mounting bracket. alot of work just to get to the bulb
