Evening all,
Well inevitably after the numerous sets of spotlights got removed a wiring/headlight problem would have to pop up.
Its all started a couple of months after i had taken all the lights off, i would notice driving to and from work that the full beam headlight warning light would glow genitally whilst the headlights were on (Not when on the side lights) this initially could be sorted by giving the wires to the back of the bulb a wiggle.
Unfortunately now it has all gone Pete Tong, the back of the 3 pin connector has melted, which i changed for a straight spade connector. however now the warning light continuously stays glowing. It is fully lit on high beam.
Looking at the lights them self, the offside light at dipped beam glows with a back feed on the high beam filament. When you switch to high beam the offside then illuminates correctly as it should on dipped beam, but no high beam.
I have tried switching the wires, plugs and fuses on the main fuse box but no luck, just wondering if anybody else has any pointers on where to look.
Cheers Jon
Cheers Jon
