Headlight Adjustment and Wiper Problem
Hi there,
2 problems with my k11 Micra, hoping for anyone to help with an easy solution.
Problem 1: Headlight adjustment switch working fine, all lights working fine, however when adjusting the the height of the beam with the switch it only does so on one side, the other stays static.
Problem 2: Rear Wiper. Functions fine when switched on, however recently when cleaning the back window, instead of the usual 2 wipes occuring automatically with the clean (same as the windscreen), doesnt occur at all. Have to switch on manually to wipe the cleaning fluid off the rear window.
Any help would be greatly appreciated.
John
1. Do both headlights have the automatic adjustmer mech? Has one been replaced with a manual adjustable one?
2. Can't shed much light on the rear wiper as I've never had one. Perhaps a stalk issue?
It can be dangerous to assume, double checked and you guessed it, only 1 has the adjustable motor! and I was so certain. What an idiot! Cheers for your help btw
