Andy652
k10 lover (not literally)
I've got a 1.0 with the low compression head and I was wondering if its possible to skim it the right amount to make it the same as the higher compression heads, or if there is more of a difference between the two heads than this?
also, how much can be taken off safely before you start running into problems and what sort of gains can be achieved by this?
thanks in advance
thanks in advance
