Salut,
I want to try a liquid gasket sealant, if only as a temp fix so I can keep driving whilst I accrue replacement parts, skills and mostly, confidence to repair manually.
Re my previous post on a leaky head gasket; How can I tell if the oil is contaminated? Apparently these sealant products will absoulutely destroy the engine if they get in to the oil/engine case so I'm trying to ensure that the only leaks are coolant and piston areas. How do I do this?
There is no obvious white residue on the oil cap, so am i safe to assume that there is no mixing of coolant and oil?
What else should I check?
