head gasket recommendation
CMF_Pierce
Hey everyone,
My pistons are dished for 8.5:1
The head and block are machined to mate, only took a thou off I think. So I should have regular tension on my timing chain.
If I have two vrs kits lying around. Should I use the gasket from it for my engine, will it hold up to turbo application?
Should I get a nismo aluminum gasket, the thin one?
How much would that raise my compression if it is thinner than a vrs stock gasket?
Any info appreciated.
Edit: ducking autocorrect
