Hi there MSC!
I was wondering if anyone can offer me any insight into diagnosing my Micra.
Since June I've been having problems starting it, initially it was the starter switch which I then replaced along with a new battery at the same time, the car went from not turning over at all to working fine for about a weekend. It has around 63,000 miles on the clock and is only driven about in town, I've had it since 2007 but it is a 53 plate 5dr SE.
Then the car seems to have developed a new fault which is very strange, it will start fine first time but if it is then driven anywhere, turned off and left for a while when I come back the car will not start. The starter motor will turn over but the engine seems to make no attempt at reacting to this and nothing will happen. The boot lid was also opening when I turned the ignition so that is now disconnected via the fuse box next to the steering wheel.
However if I say come back to the car the next day it will fire up fine, the engine sounds like it's running perfectly so I don't think it is timing chain related. However after repeated attempts at starting the engine warning light comes on, with the error code warning about the CAMSHAFT SENSOR. I have taken the car to two different garages, one a Nissan specialist and they both cannot find a mechanical fault anywhere and cleared the code, a mechanic from the second garage did however say it could be an anti-theft error.
Nissan have been less than helpful as they want to charge £85 just to look at the bloody thing and then never seem to have anyone on the other end ready to take my call.
The strange thing is this error seems to be completely random and is very annoying as you cannot go anywhere and guarantee that you can come home as the engine will not turn over. I was planning on using the car this summer with friends as I only past my test last year and I'm miserable as a result because it keeps letting me down.
Does anyone have any ideas, just to summarise I have:
Replaced the starter switch, (which made the car work fine for a weekend until this starting problem occurred)
Replaced the battery; again the car worked fine for about two days after doing this.
Put in a whole new tank of fuel to burn off anything that might be causing problems.
Put in new oil although the car barely uses any anyway.
I've honestly ran out of ideas how to fix it and everyone else online seems to have had the original problem with the starter switch and then their cars' have worked fine.
Any ideas anyone, otherwise it's going to sit unused outside the house gathering dust
