Having a clear-out
Hey everyone,
Time to get rid of all the Micra related stuff I have lying around as it's taking up precious space and I can't see myself ever using any of it.
First up: Some 4x100 Alloys. These are labelled as FOX 5B on the back and are 15 x 6.5J (not sure of the offset but can get some pics up of them fitted if anyones interested in how they would look). I have not had them fitted since owning them. If anyone is wondering how I have a picture of them on the car its from before I bought it when Shaf (another member on here) owned it.
Two of them have 195/45 R15 78V GT Champiro HPZ-45 tyres, whilst the other two have 195/45 R15 78V Admiral SP712 tyres fitted. All of them are legal, the Admirals and one of the GTs have a decent amount of tread left, but one GT is a bit on the low side.
All the wheels could do with a respray to bring them up to a decent finish, as in some places they have gone back down to bare metal below where the paint has come off. Its nothing a rattle can of Hycote wouldn't solve.
A Pipercross foam air filter. This was fitted about 3-4 months ago as I was impressed with the one I fitted to the first micra, it makes a nice deep sound and seems to ever so slightly improve throttle response and fuel economy. I've just fitted a bigger GA16 airbox and therefore this no longer fits.
I've also got an Alloy Ripspeed Gear Shifter, this came on the car when I bought it but I swapped it for a D1 Spec one. It clamps onto the gear stick using allen bolts and has a decent weight to it, making shifting smoother and easier than normal.
A Full Rear Wiper Kit including all of the mounting hardware, motor, rubber grommet and wiper arm.
A Spare Throttle Body. This has been re-soldered and works fine, it didn't provide the same fuel economy as the brand new I bought for £100, but it wasn't a hugely noticeable difference (maybe 35mpg compared to 40mpg) definitely not worth the £100 I spent on the new one. It came off a 1997 1.0 K11.
A Indicator Stalk with Front and Rear Fog Lamp Switch. I bought this to fit but ended up using a wiring kit and relay instead. This is definitely a neater alternative and matches the stalks in the newer pre-facelifts perfectly.
A NATS ECU. Not sure how much use this is, but thought I'd stick it up in case anyone has a use for it.
I'm looking for:
Wheels: SOLD
Pipercross Filter: £20 including postage
Gear shifter: £10 including postage
Feel free to make me an offer on the rest of the items.
Thanks,
Calum
Hi, would you send me the grommet that you have used to plug the hole for your rear wiper. I've taken off my rear wiper but I have duct tape on the hole at the moment as I can't find a grommet. The only ones I han find are from Hong Kong.
I can send you one if you like, probably easier to buy it off eBay here for 99p inc. delivery ( http://m.ebay.co.uk/itm/281026511967?nav=SEARCH&varId=580159494069 ) though.. The ones I got are 32mm iirc. If that doesn't work for you I'd be happy to send you one if you cover the postage. Ironically I had to order a 25mm one today as I de-wipered my Vectra :p
Sorry Calum I've been a plonker, I'm fitting driving lights not fogs so I don't want a fog stalk. Doh. Cheers anyway.
No worries, if you already have the wiring loom and connect it to the driving lamp cable they should just come on with full beam. On my last micra the wiring for the lamps was cut so I just used a lamp wiring kit and dash switch, they then had to be turned on and off manually though..
